Speaker replacement
bet93
Apr 22, 2011
St. Louis, Missouri
Hey guys, I just bought speakers to replace the ones in my Talon. It's a 1997 with the Infiniti premium sound. From what I saw, the dash speakers are 3.5", the door speakers are 6.75" and the rears are 6.5"
I've looked around more and now I'm concerned I ordered the wrong sizes. Now I'm seeing that the doors are 6.5" and the rear are 6x9.
I've searched around and seen both. I'm hoping somebody can step in and clear this up for me. It would be very appreciated.
(Side info: I am replacing the radio as well)
Thank you
if you are looking for the best sound i would consider a component system that will replace the tweeters in the dash as well as the doors. They might be a little smaller but you can make them work, and the doors will be a good fit. I have the infinity kappas and they are crytal clear.
Thanks a lot guys, at least I only need to reorder one set of speakers.
A componet set is def the best idea. Try onlinecarstereo.com or sonicelectronix.com
I did a component set in the rear. easiest way I did it was to ask the shop I purchased my components from for a sheet of abs black plastic. Cost me $5. Went home, pulled the plastic brackets for the 6x9, made the outline template, then created the inner diameter using the speaker template. Some epoxy, screws and a dremel and about 1-2hours. Sound was far better then have the 6x9 in the rears.
Looks like the doors are 6 1/2 and the rear are 6 1/2 and 6x9. I think it depends on the eclipse, I had 6 1/2 on the gst rears and I bought some 6x9 on the rear for the gsx eclipse but the gsx end up having one 6 1/2 bracket and one 6x9 bracket. I end up getting the bracket for the 6x9.
