spark plugs high speed glazing
trevnasty
249
Feb 27, 2008
kalispell, Montana
ok as the title say high speed glazing now is there a way to change this other than buying a colder plug i have hgk plugs there a 7 in rate of cold know as far as i can find out ngk makes there plugs go to 9 so is the only way to solve this by buying colder plugs thanks for the help :thumb:
Trever
BPR8ES ok i em running this kind of ngk plugs there for a motorcycle like the title said high speed glazing so does any one else run a ngk BPR8ES?i was runing BPR7ES
I have no idea what you're asking? Did you go to grade school? Can you write properly? Fix your post and then maybe someone will try to help you...
i'm running 8's, wouldn't recommend them unless your car sees above 25psi, im running 28psi daily and so far they are great.
