BurrowZ
- 836
- 5
- Nov 28, 2010
Duluth,
Minnesota
Made a new thread because I did a little more work and research and made new discoveries.
LONG story short: Car won't run after head swap. Starts but won't run.
I believe it is the injectors not firing. I am getting spark (yes I checked, so don't waste my time by asking) and timing is dead on. I checked that for the 4th time this morning.
Pulled the fuel rail off the head and rotated my 1G CAS by hand. The injectors seemed to fire intermittently. It was tough to tell because they would not stay in the rail and the pressure kept pushing them out, resulting in fuel sprays everywhere.
Things tested and known to be working:
-Resistor pack
-Injectors (brand new)
-ECU (which is a 95 eprom, spark plugs swapped properly)
There is only one known issue with the car and that is that my battery does not hold a charge very long so when I try to start it I keep a battery charger running @40 amps on it. I'm stumped and honestly will a new battery be my solution? It ran fine and battery was fine 4 months ago the last time the car ran.
-Resistor pack
