sooo the dsm dies
waltz
37
May 16, 2009
montoursville, Pennsylvania
(hurry up and read before its deleted, for whatever ### reson i cant post to classifieds) well guys im getting rid of my 90 tsi awd.the motor was rebuilt by the kid before me, and it just blew the head gasket.im willing to sell the car as whole to who ever wants it, but ill only travel up to 50 miles to deliver it. car still starts and runs but overheats very quickly. The body has 106k and the motor about 6k..full price of the car is 1400, or ill part it out. below is a list of all the parts that are in it, if you see something you need pm me and we'll talk prices.
SUSPENSION
energy suspension bushings
front KYB struts
DRIVETRAIN
New oem Clutch
new slave and master cylinder
short throw shifter (n/i)
GOODIES
front mount w/ custom piping
turbo xs RFL BOV(made to recirc)
big 16g evo turbo9i have pulled it out and is in good shape.)
stock 1g bov laying around
EXHAUST
3" turbo back exhaust w/ meghan racing downpipe
HKS Racing 3 1/4in. to 4 1/2in. out muffler
3inch high flow cat
2g ported 7cm2 manifold
ENGINE
Topline gaskets, pumps, the works
bored and honed 20 over
Ported and resurfaced head w/ new seals
hks valve springs
hks 272/272 cams
Balance shaft eliminator kit
ARP head Studs
Performance 4 layer metal head gasket(blown)
Stainless steel exhaust manifold studs
performance radiator hoses
Prothane performance motor mounts
ELECTRIC
SAFC tuner
autometer boost gauge
oil pressure gauge
tri gauge pillar pod
magnecore 10mm wires
eprom socketed ecu stage three chip. programmed exactly for this car. chip can be reprogramed
FUEL
560cc injectors
AEM fuel pressure regulator w/ stainless steel line
6an bolt on fitting
walbro 255 fuel pump
Im sure im forgetting some things.
The body is in great shape(other then the paint), if you give me your email ill send you pictures
You can't post in the classifieds because you're a new member and haven't met the required minimum tech post count.
Had you read the rules you'd know that already, and you'd also know that there are NO CLASSIFIED ADS ALLOWED IN THE TECH FORUMS. Post this on your local forum....scroll down below the Hangout section and find the local forum closest to you.
