Some sort of spark loss ?
mmats2g
Jan 24, 2017
Regina, SK, Canada
Hello fellow dsm'ers I have a 1995 eagle talon tsi awd automatic transmission ..gaskets hoses timing belt and all are replaced. It has a 14b turbo. Now my problem is I have searched but can't find anyone else with the same problem witch it when I give it the beans on a roll (60-80kmh) it looses spark to 2 cylinders then proceeds to shutting off and won't start for hours unless I unplug the battery for a min then will fire right up and drive normal ! It only happens on highway WOT pulls hopefully can figure something out ..also I have done lots of boost leak tests please help
Might be an ECU issue. I would pop the cover off and have a look inside it.
I will pop it open tomorrow hopefully no leakage or anything that would suck mainly cause dsms around me are far and few to picks parts from
Computer looks good and tested coil. I think it's the power transistor when it hepens I unhook it's plug and plug it back in and problem goes away so I'm going try find one at a salvage yard ..now I'm going to start the wire tuck and 1g cas .
