Some sort of cut
Pa97dsm
Jul 26, 2013
Woodlyn, Pennsylvania
Once I hit around 15lbs of boost at about 4500 rpms if I floor it the car will almost feel like I hit a Brick wall and sounds like its red lining, but not absolutely positive if it is fuel cut because it does not make the car shut off and it still runs fine after that. Also if I accelerate slowly without flooring it this "cut" will does not happen. Only when I floor it. I have an MAF translator and also an SAFCII by apexi. Can anyone narrow this down for me, or maybe even come help me diagnose it if you're in the Philadelphia area? Thanks guys
Having the same experience with my 97gsx, now to a lesser degree after a tuneup.
I have stock everything aside from a big16g i swapped in when the 14b crapped out.
I'm now also getting what sounds like lifter ticking. :(
Do any of you guys have a logger? im in northeast philadelphia , if you guys are local im more than willing to help out .
  • Wanted 6 bolt NT water pipe
    • chrisman287
