TurboSpider
- 223
- 16
- Nov 2, 2015
York,
Pennsylvania
So I go out to really check out the engine of the car that I just got last week. I knew the car was leaking oil before I bought it, but had a hard time checking it out on the lot. I noticed there was a good amount of oil and possilby coolant that was wet on the left front side of the engine. I pulled the top cam cover and noticed there was some oil on the block behind the cams. Also to the right of the turbo a hose appears to be wet. The banjo bolt that goes into the turbo looks ok. Do you think this is all from the valve cover gasket? I am pretty sure that is leaking at least because the top sides of it look wet.
