So the HP is in the filter not intake pipe?
Race94
1,151
Jan 6, 2003
Puerto Rico
I was wondering if this is correct because i was thinking of getting an intake pipe but i'm running a k&n knock off filter.
How much HP should i expect?
You will also here notice a better (louder turbo) SOUND as well. The hp comes from both. You may see 1-10 hp gains that equals almost nothing in the end (or when it is measured at the wheels).:thumb:
They are correct, the only benefit you will receive, is faster spoolup.
(Not a bad thing at all.) :cool:
you won't see much max hp increase, but with faster spool, you'll get a little more down low. Not much, but a little.
yes
yes, if it does its job then keep it. If in time it looks ragged spring the extra for the K&N reusable and see if you can tell for yourself!
honestly just buy a K&N, I forget where the link is but there was a test including 6 orso of the big names, HKS,apex'i, K&N etc...anyways It was K&N and the 3x more expensive epex"i who won.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
