So I'm back, and I have a question about wheels...
TheWanderer
149
Oct 26, 2007
Reading, Pennsylvania
Hey guys, long time no post. Recently picked up a 93 VR4, and am wondering if anyone knows if the 1G DSM 16" steel rims will fit on it without a problem. Looking for something run snow tires on in the winter...
I've asked this question over at 3si, but no definitive answer, just a possible "the offset may be wrong" deal.
So can anyone tell me what the offset and spacing on these rims is? Could also use sizing help for tires so that I can keep my speedo reading as close as possible (going from 245/45/17 down to a comparable 16" tire)...
5 lug AFAIK. Would have to look again, haven't been paying much attention to it lately. More concerned right now with getting the heads swapped over to fix the bent valves from the belt slipping :( stupid previous owners LOL...
Your 3/S has a 46mm offset and DSMs I believe run around a 35mm Offset but this should not be a problem if you are just wanting to use them for winter tires. If you were running Auto-X, that would be a different story but you should be just fine.
Thats what I wanted to know :) Thanks!
I suppose if I really wanted to, I could run spacers, right?
You could but I wouldnt reccomend it. The only thing you may notice is that your wheels may sit in a little farther but you should have no problems with the turning radius or anything and for winter tires I wouldnt even worry about it.
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
