Spoolin92GSX
- 491
- 4
- Oct 4, 2011
Inland Empire,
California
To give a very small back story, I've had my DSM tuned to 11.2:1 WOT AFR for a few months and it's seemed pretty happy there on 91 pump gas. After a recent canyon run with a buddy on his R6, I noticed my manifold glowing a little and decided 11.2:1 is still a little lean (I unwittingly ran close to 12:1 before getting tuned and it glowed A LOT more).
So I went to tuning last night and got 11.0:1 pretty smooth all the way through the RPM range +/- 0.1:1. Here's my question - at 11.2:1 it would pull butter-smooth up to 6000RPMS (that's just as high as I rev right now), once I had 11.0:1 locked in, I can feel just the slightest hesitation during a 3rd gear pull.
Compression test was done a couple weeks ago with 150psi across all 4, brand new NGK plug wires, BR7ES's gapped to .028 with a few thousand miles on them, Walbro 255 rewired, AFPR, clipped 16g. I know there was 1 or 2 counts of knock but that was remedied with 1* of timing pulled from those cells, and I know my 450cc injectors are pegged, but the hesitation happens maybe around 60% duty cycle. I was going to attach a log, but TunerProRT's log files aren't supported.
I'll probably end up leaning it back out a tad until the hesitation goes away, I don't romp on the car that much anyways so it's not a HUGE concern. I've seen 16g's glow a LOT brighter than mine and last with no issues, so meh.
I'll get the AFR's back in the 11.2 range. Also, I think I was having a derp moment when I felt the hesitation, or the car was having a derp moment, after I fixed my base fuel pressure it hit as rich as 10.8 and pulled fine
