boosted_91_tsi
- 303
- 9
- Sep 1, 2002
Cary,
North Carolina
Well I was headed home last night from work when I heard a strange noise out of nowhere and as I came to a stop at a light smoke soon followed. I pulled away from the light and was unable to build ANY boost at all. I took the next turn off to check everything out. When I got around to checking the oil, I pulled the dip stick out and smoke followed. I checked the oil and it was right on. I opened up the filler cap and more smoke came out. After it cooled, I limped it home.
This morning I took off the intake and found that the shaft had alot of play. I went ahead and removed the turbo and O2 housing to get a better look at the damage. I have yet to separate the two but from what I can see all the fins are still intact. I know the turbo is basically shot but is there any other damage I should look for? I am concerned about the smoke and wonder if there is more to it.
A few specs: stock 14b, I do not know the color of the smoke as it was at 10pm this happened, I was running an open downpipe when this occurred and I didn't know if that could have any effect on the turbo failure at all. I do have some future plans that include a 50 trim and supporting mods (fuel, DSMlink, IC...etc.)
Please help me figure out what happened and what other damage to look for.
Thanks for the space
