smoke from door vents.
codym
636
8
Dec 28, 2011
Amarillo, Texas
Today I was driving down the highway, about 80 mph, and i noticed smoke began to fill the cabin from the adjustable side vents on the doors. It was a grey ish smoke, didn't really smell like burnt oil smoke ( my valve cover used to leak and drip on the exhaust) I have never heard of this happening, and is rather unpleasantly. It's happened a few times before , but I had the Windows down so it didn't seem as bad. Any help would be much appreciate.
I've taken both door panels off and looked around. All the wiring seems to be ok. I'll look at the heater core tomorrow and see what its doin. I'm bout to drive this pos into a lake -_-
dont just look inside the door pannals. look at the harness that goes between the door in the rubber boot. thats a common pintch point. the boot can wear and cause wires to chafe. if you still dont find any wiring problems id look at the heater core as i mentioned above. good louck
Ill try it on a day I don't have work. Also when I turn on the defrost LOL it actually dosent defrost it. It makes it worse. Just thought id throw that out there for anybodu that has that too.
this is most deffinently your hvac. just find the black box and look to see if its the core or the heater hoses, then replace what ever is bad. good luck
It's all good man. I looked and the wiring is fine, no smoke coming from any wires. I meant to look around at the heater core and see what its doing , just got a little distracted.
