Vividus
- 0
- Dec 20, 2005
Reno,
Nevada
I own a 1990 Eagle TSI AWD. Original Owner. About eight years ago, car made a bang sound and some smoke would wisp up from the turbo. Then it wouldn't pass Smog.
I took in to dealer and they said I needed a new engine. Not wanting to part with the car I put it in storage for four year and got a new truck. I then had to move it from storage , so I drop some gas oil, change and new battery and it ran better than ever. So I took it to SMOG, it barely failed. Guy there told me to get new wires and plugs and it should pass which it did. One of the spark plug was missing the gap arm. Apparently the dealer didn't even check it. I drove the car for a couple of weeks and the wisping smoke was back. So on a hunch I pulled off the turbo and manifold. The turbo and waste gate was fryer, looked like lava on the inside, totally burned. The manifold also was cracked really good. So I put it back in storage for a couple of years while I bought parts for it. This pass month I had the Big 16 Turbo and wastegate, improved manifold and a 190 fuel pump installed and the oil changed. I took it to Smog and it wont pass. At idle it is 300/220, failed but at rpm it was 120/220, pass. It appears, if the car runs there isnt much smoke, if any. But if I let it idle a while like at a long stop light, puff, big cloud. My mechanic says to drive it awhile, because the rings parts might be dry. Ive put 500 miles on it now and it is still the same. My mechanic says the compression is good. The car running really really well, but the smoke and not passing smog is bugging me.
Ive also tried gas treatments, Nothing. Any ideas? Sorry for the long string. Car has 135k on it mostly highway miles Thanks.
