SMIM install?
Gamble97
2,642
63
Jan 3, 2006
small town, Illinois
I put on the smim awhile ago, but not I have to go back and tighten all the bolts to make sure they are all tight. I had a really easy way to get to the bottom bolts, but I forgot. Now for the life of me I can't figure an easy way to get to the bottom bolts on the intake manifold. What do you guys do?
I haven't jacked her up yet, but can you get to them from under the car, maybe?
Hmm, maybe I'll try that tonight> i have the heat barrier gasket on there. What should they be torqued to?
24ft lbs?
i never had a problem getting my lower bolts from under the hood, the torque specs im un sure about, I just tightened mine hand tight, maybe 30ish ft lbs, hasnt leaked ever. (also run the heat barrier gasket)
I dont think i relocated anything on the driver side firewall taht would make more clearence other than ditching the emission control solnoids..
Not sure about your 2g, but on my 1g I took out the battery and got to the bolts from the passenger side.
