Smelling gas
samus21
150
Jan 27, 2012
York, Pennsylvania
I'm smelling gas when I drive my rs eclipse only when the windows are down. I also don't smell it when the car is still aka stop light or in park. What could cause this?
I replaced all of the o rings on the fuel injectors a while ago but i still had the issue but since the fuel pump was replaced i havent smelled it since hopefully that was the issue.
Have you checked the filler neck? You being up north could have rusted it to the point where it is soft and will leak fumes. Mine is currently throwing an CEL for Large EVAP leak for that.
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • Wanted 2g Trunk/fuel door release lever
    Looking for a 2g black fuel door/trunk release lever in good shape
    • jesse12345
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • Wanted 1g 6bolt Balance Shaft
    Does anyone have a rear balance shaft for a 1G 6bolt hanging around? For some reason, this one...
    • Gabe92RTTT
