Smelling gas
samus21
150
Jan 27, 2012
York, Pennsylvania
I'm smelling gas when I drive my rs eclipse only when the windows are down. I also don't smell it when the car is still aka stop light or in park. What could cause this?
Check the fuel injector seals(make sure they are still rubbery and not hard) and fuel rail for leaks. Also the little hoses on the fuel regulator are connected.
This may sounds stupid but where are the fuel injector seals, fuel rail, and fuel regulator?
On the 420a engine(which is what you have) The fuel injectors are connected on the fuel rail which is in between the intake manifold and the black valve cover(behind the cover that reads "DOHC 2.0L 16 valves")
Try removing your rear seat, the 4 screws that should be covering your fuel pump access, and check and see if either the ring that secures the fuel pump assembly is doing its job as well as if there are any leaks in that area. Also check under your car to make sure you are not leaking fuel.
I had a similar issue with my 2005 Pontiac Grand Am. It was my fuel pressure regulator going bad. After I changed it I had no more problems.
Your fuel pressure regulator should be located opposite end of the fuel feed line on your fuel rail.
Hope this helps
Was it the oring or what? The injector itself can't leak can it?
better lube them up before you put them in or youll have the same problem. hahah sorry if you already know this.. seen it happen too many times
Hey sorry to bring up old issues but im still having that fuel smell. I can smell it around the back right tire and I dont smell anything in the engine bay. should I check the fuel pump? i visually inspected the fuel lines back there they look to be in good shape. I did also put the fuel injector seals on and it didn't fix the issue.
i smelled fuel in my rs from the back and was heavy where my pump is. i opened it up and had no leaks and tightned the screws to make sure it wasnt just lose. few days later my fuel pump went bad. My hose was pinched and the pump was working harder to try and get the fuel to the rest of the car which explained the strong fumes. I wouldnt just overlook this like i did and have your pump go out on you.
o okay. I unscrewed the cover to the pump and I did smell a bit of gas my next question would be should I put a steel braided lines just so I don't have to do this again or would a regular rubber hose do? Also what size hose will I be looking for.
unless you are running more then 600hp i would not go with braided lines. yes it is a piece of mind that you will most likely never have to upgrade again, but unless you have the extra money sitting around just go with stock hard line replacement i believe factory is 5/16.
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • Wanted 2g Trunk/fuel door release lever
    Looking for a 2g black fuel door/trunk release lever in good shape
    • jesse12345
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • Wanted 1g 6bolt Balance Shaft
    Does anyone have a rear balance shaft for a 1G 6bolt hanging around? For some reason, this one...
    • Gabe92RTTT
