Smell of gas??
gsxeclipse97
1,255
Nov 7, 2004
Cedar Park, Texas
So as I mentioned we installed the evo fmic today we went through and fixed all piping issues and got everything settled. So I thought, I now smell gas under boost. Which I didn't before. And sometimes under cruise. Still same setup fuel wise so not sure what is different really.
Gas as in burnt gas (rich) or unburnt gas (leak)?
Well, if you happened to run more boost you are inherently running higher fuel pressures. You sure the hanger seal is good under the back seat? I had the same problem after i crammed in the walbro 450. Had to seal it up and no more gas smell. Im just throwing something out there, might not be the case for you but worth a shot. GL bud
