small 16g questions
dustin_8907
83
May 7, 2008
Ripley, West Virginia
Here's a list of mods I have thought about getting together but don't know if they will work.
jdm cyclone motor
ported small 16g turbo
3" turbo back exhaust
2g ported exhaust manifold
o2 sensor dump housing
better air intake
boost controller set at 16psi
190lph
I was wondering if I could run this setup with stock injectors and no fuel tuning computer. If anybody knows if i would have to or not let me know. Thanks for your help!
you should really invest in bigger injectors so you dont run into fuel cut. to deal with tuning it can be argued you dont NEED something but it would be in your best interest to get something cheap, like a maft or maybe a used safc etc.
I think that you will be running pretty lean at 16 psi with 450s, why not just some 550s?
So I wouldn't run into any problems if I just put some 550s in it. Would I have any drivability issues or anything?
You wouldnt be able to boost more than the 16psi, and you will needs something to tune them with. Either a Maf-t or SAFC-II.
I'd stick to around 15 psi on the stock injectors.
If you switch to 550's, you'll need an AFC so that you won't run so rich, so that you can turn up the boost a little, and so that you don't hit fuel cut.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
