Small 16g compressor wheel question
Blu92
117
Aug 20, 2011
Dale City, Virginia
Got a used 16g with shaft play for a few bucks. Everything looks good except the turbine shaft is snapped and the compressor wheel has notches in it. They look like they were machined not damage so I thought maybe they were for balancing the wheel. Any opinions? I know I'll need a turbine shaft and rebuild kit. Just wondered if I should replace the compressor wheel too.
It looks a little dirty, but no scoring or scratches or metal dust anywhere that I can see.
Can't figure out how to put up a pic on a reply, but there is an area around where the intake connects to the housing basically a ring where the metal looks clean while the rest of the inside of the housing is dirty. It doesn't look scored or scratched, but I guess if the housing material is harder than the wheel it may not have been damaged while the wheel was contacting it. Guess I'll be saving up for a comp wheel too. Thanks for the help. I didn't notice the flattening of the edges at first.
Yeah it looks the same. I already figured I'd have to get a new turbine wheel since the shaft snapped. After looking at prices for a new compressor wheel, shaft with turbine wheel, rebuild kit and heat shield I'm think I should just get a new chra. Would an evo3 chra fit the small 16g compressor housing or should I just get a small 16g chra?
