Slow Times Somethings Wrong
MrideM
Sep 10, 2005
brecksville, Ohio
Ok had my 2g rebuilt with 6-bolt 1g motor from Buschur about two years ago. I got out to the track yesterday for the first time after swap at same time most of mods where done. And this just is not right I ran a 15.3 around the same time as bone stock. Help what to do safc is all at zero every ones 2-cents please. Thanks
I don't see injectors in your profile, also have you got a logger you can post a log of a 3rd gear pull? Something isn't right there at all unless you are a TERRIBLE driver.
I can drive, dont have a logger I have a obd II scan tool with testers it does may be that can tell me somthing I dont know. Also how do you do a leak test for boost even though I dont think its that because it held 16pounds. There a code that will come on p1105 enhanced dtc will this mess with my power that much, thanks
Does the car drive fine? Those are some bad times for 16psi of boost, Do you know how to tune an AFC?
My friends 90 GSX with 15psi intake and exhaust ran a best of 13.9, all of your times seem really slow for what it is. Are there any problems driving it?
