slow clutch pedal
dsm dominator
47
Jul 18, 2004
guelph,
i am having two problems actually
the first as the topic states is my clutch pedal is slow coiming back up, if i am shifting quickly i can feel the pedal smacking the bottom of my foot.....not nearly as responsive as it once was. It is starting to make me agry because i hoped after changing the fluid and bleeding the system it would fix it, but alas....slow shifts for me
the second problem i am having is my read end fill plug is SEIZED, i cant get it off for the life of me, sockets wrenches, and even the biggest pair of vice grips i can find....no prevail (they were even these fancy new vice grips that clamp like 10 times better) any suggestions?
thanks
i checked the slave and master cyl, they seem to be fine anywere else that i could of sprung a leak?
i can try that....stock restrictors? i thought that was only on 2g and up?
thanks for the help everyone...keep the suggestions comin!
My clutch did this, then I had to replace the master cyl, slave cyl, and all clutch lines.
there was no fluid in the slave, it should still be good i just had the master & slave replaced this summer,
o and by the by is it worth it to get stainless clutchlines?
