Slave starting to go ?
ZexmeUp
53
Mar 21, 2004
i, California
I just noticed this today, If i just push the clutch in and start to drive its fine. There is a problem when I hold the clutch in for about 15 or more seconds... It starts to engage by itself. It doesn't go all the way but to where it will engage right off the floor instead of engaging half way when I let the clutch out. I checked my fluid and its normal and isn't leaking anywhere. I'm not sure what it could be, maybe either the slave or master ?
What do you guys think this is ?
I picked up a new one for 18 bucks. You could rebuild but and I have before but this is a little peice of mind.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
