Is this my headgasket starting to go?
K Dan
615
Aug 6, 2002
none, Nebraska
I was checking my oil today, and the dipstick looked like it had a greenish tint to it, i took the oil cap off and there was some milky stuff on the inside of the cap. Lately my coolant over flow can can seems to loose coolant rather fast and when i start my car up in the morning the the exhaust is a little white but goes away after i drive around for a while. Is there anyway to confirm this before i pull the head off?
do a compression test. If you're low in 2 cylinders that are right next to each other, then it's the headgasket. But if you have water(coolant) in the oil, a bad headgasket is a good indication.
  • Wanted 2g Front Mudflap Set
    I am looking for a set of front 2gb mudflaps. Will pay a fair price plus shipping to 14216. I...
    • EclipseDSM59
  • For sale 1g 1993 Eagle Talon TSI AWD
    1993 Eagle Talon TSI AWD $9,500- Clean Title in Hand ( in my name ) - 95,600 miles ( 3,600 on...
  • For sale 4G63 1G OEM Knock sensor
    1G OEM Knock sensor Came off a running car$85usd shipped Lower 48/Canada
    • Dsm_canadian_mike
  • For sale 4G63 Waterline sets with bolts
    Water line sets. 45 deg and 90 deg in each pair. With banjo bolts. . Have ten sets like this...
  • For sale 4G63 1g cy head with 2g intake ports
    1g style cy head. Bigger end studs on exhaust port. 1g Waterneck. 2g intake ports. Great cy...
