Slave cylinder rod length?
adamgt1
Oct 9, 2003
I did a search but was unable to find the proper information that would lead me to the acutal lenght of the slave cylinder rod.
I pulled mine today, and it measured 85mm or 3.35". I would like to determine if it has been upgraded to a TABOO (1/4" longer rod) by the previous owner.
Car is a 1G AWD.
I'm wondering the same thing. I'm battleing a disengagement problem with an ACt 2600 and was told I have an extended slave rod but wanna rule it out before I drop the tranny. My clutch pedal assembly is at full travel. :(
I've got both right here in front of me, and just measured them. The extended rod is a little over 3.75". Just barely over that. You've got a stock slave rod.
I know this is an old thread but, if the Taboo ext rod is 1/4"(.25) longer than stock, one of you has the wrong length... 3.75" - 1/4" = 3.5" not 3.35... Any thoughts? I'm also battleing disengagement problems as well and I'm little confused about the actuall rod lengths...
I bought mine off ebay, and I just measured it again, just over 3.75" like I said before. Not sure it my extended rod is just a 1/4" longer or not, but I wouldn't use it anyway.
any chance someone could get a stock re-measurement for me?
