Slacking a bit
welfle18
474
Sep 14, 2006
Norwalk, Ohio
Have been slacking a bit since the start of the build. My buddy is finishing up some minor porting of the head this week and will begin to polish it shortly. Was originally going to remove the ac to clean up the engine bay but since changed my mind. Did a little sheet metal work to the strut mount towers in the engine bay since the one completely rusted through. Other than that no pictures to post but will next time I am out. Bullseye is pretty much killing the process since they are taking forever to cast new turbine housings. Other than that the engine bay got a good grinding on to remove alot of surface rust and some minor rust through problems. I will post up some pics sunday when I go out there to continue my engine bay clean up. Until then just three more parts need to finish. Some cam gears for my nasty kelford 272's (delta), some prothane motor mounts, and finally the bullseye hx35 cast turbine housing. Peace.
