Sideskirt Help
milenium99
45
Jun 9, 2004
bronx, New York
Anyone know how I'm supposed to attach urethane skirts to the car? Selling my stock ones so I want to put these on.
Thanks
Junior
I don't know about a 1g, but for the 2g you use self-taping screws, about 5 on the inside of the door, a couple in the rear fender well and a couple in the front fender well. Don't use double-sided tape, it'll most likely fall off and you'll end up running over your skirt. Just line it up where you want it, look for the most unnoticable spots that you can drill and screw/bolt into. I'm guessing this kit didnt come with pre-drilled holes?
No problem. Try and do it in convinent locations as well, if your car is lowered you'll find yourself taking off the damn skirt everytime you want to jack the front end up. I can take my skirt off in about a minute without an assistant(and just under 5 minutes to put it back, a bit harder when lining it up to put it back on).
  • Wanted 6 bolt NT water pipe
    • chrisman287
