Shutters and hesitates when accelerating at about 4k
deyoungtsi91
Jan 24, 2011
Columbiaville, Michigan
I have read some diffetent things but cant really find an anwser to my problem. After about 10 minutes of driving my 91 TSi starts to hesitate and shutter a bit at WOT as soon as I hit 4k. Iam also idling high like 1400, not sure if that would make a difference. I just put in new plugs and a new fuel pump. The car was doing this before the new stuff btw. I put in Bosch Platinum plugs but I read in a few places that NGK plugs are the way to go so I am not sure if that is the problem. My best guess would the plugs or possible O2 sensor. The wires and coil are also newer. Any help would be awesome. Thanks :D
what are your plugs gapped at?
Mine does this above 5500 rpm if my Spark plug gap is above 28 I try to run mine at 24. It also causes my car to idle at 1200rpm with the gap above 28, and 1000rpm at 24
Will the NGK iridiums be the best? Also, I found the box from the new plug wires and they were a cheap knock off brand Ive never seen before.
