Showcase: Auto-tuner for the VE map on SD setup
basshead
46
15
Sep 21, 2007
Sweden, Europe
Hi all!
I finally made the 30+ post mark. :)
My name is Kim (male) and i have been into writing code for the 1G ECU for some years. To many to remember actually.
I am the developer for a Speed Density code named Swede Density. The code does not have any code left from the MAF so this as close as you get to real SD.
Anyhow, some of you might know me some don't. So i thought i'll show you my latest project.
A auto-tuner for the VE map. Everyone that has a SD setup knows the pain involved mapping a totally clean VE map.
This app takes care of that.
You just set you AFR map to desired values and the auto-tuner does the rest for you. In real-time during driving.
Here are a few screenshots during development:
Armed and waiting for trigger to be tripped. Here i use 2000 RPM and and over 1 BAR boost. (1 BAR relative to atmospheric pressure.)
Triggers tripped and gone from just armed to actually mapping in real-time, while you drive the car.
Example of how a dev map looks like.
Showing both the actual VE map and the dummy O2 history map.
Check out these videos for the auto-tuner in work: KaxLon - YouTube
I made this thread to show that the 1G ECU is refusing to die and hand it's glory over to the newer ECU's.
Thanks for reading and watching! :)
PEACE!
PS. Some find threads like this offending and get upset of the "self promotion". I am just showing that development still push forward in the ECU department.
There's a difference between trying to sell or promote a product, and showing a PoC. I believe you are doing the latter. :) I'm glad people are still out there pushing the envelope.
