Should I delete the Boost control solenoid or leave it on
Norcalgsx707
564
Jun 28, 2012
lake county, California
I have a Hallman Mbc, Should I just eliminate the boost cylanoid? and if so how do I do it properly without messing things up? just for reference im running a 16g with no nipple the nipple is on the j-pipe?
My goal here is to eliminate any potenital boost leaks, and to clean up the engine bay, want things to look cleaner and want some easier access, I hate 3 foot lines running off my boost controller it looks retarded and seems to me like it would effect boost, anyways let me know what I should do? im also thinking about elminating the crusie control it dont work anyways...
So how are you connecting the mbc? Eventually you will just be using the hallman. Just leave the stock bsc in the car its fine.
You do not need the stock BCS, the MBC will take it's place in terms of boost control, you will not get a CEL by removing the stock BCS unit, it will not longer be needed.
