SHould I change the fluid in my LSD?
Royalty
904
Apr 30, 2004
norfolk, Virginia
I have the redline fluid already, i was just wondering do i need to chage or shoudl i changet he fluid in my differental?
if so then how?
Drain and refill the rear end with the appropriate type and weight gear oil (look it up in your shop/Haynes/Chilton manual, which you should have). The limited slip differential is a VISCOUS unit, requiring no maintenance or any kind of special fluid or additive like clutch-type LSDs do.
