Should i buy this modified 92 talon tsi?
talontsiboy24
868
3
Mar 28, 2009
60457, Illinois
There is a 92 talon tsi awd for sale. dude wants $3000 with these mods on it what do u think should i let it pass or get it? What questions or concerns would u have about this car?
10,000 miles on motor
Work on block and head done at Apex Engineering. Receipts on hand.
Balanced and blueprinted
Balance shaft elimination
2g pistons and 1g rods
2g polished crank
MLS head gasket
ARP studs
3g big hole lifter and rocker kit
New knock sensor
Polyurethane motor mounts
Parts from Mitsubishi 10000 miles. Receipts on hand.
All oil seals, front and back, as well as front cover gasket.
rear main seal housing
flex plate
water pump
timing belt and tensioner
alternator and belt
aluminum radiator
battery relocation kit
INTAKE
non-turbo throttle body/ non-cruise cable
2.75" aluminum upper and 2.5" lower piping
Greddy Type-S bov (not a knock off)
Road Race Engineering front mount
Evo 3 16G turbo/ less than 5k miles, zero shaft play
Turbo XS manual boost controller
EXHAUST( surface rust but no leaks in it he says)
tubular header 5k miles
tubular O2 housing w/ external dump
custom 3in turbo back, optional dump before high flow cat and Apexi muffler
FUEL/ENGINE MANAGEMENT
Socketed EPROM ECU Chipped(it was chipped but it has no chip now he says)
Apexi Super AFC 2
560 Evo 8 injectors
Walbro 255 fuel pump
2g Auto trans with lock-up torque converter 50000 miles/ shifts hard and precise
Manual shift box
fresh fluid, Mitsu Diamond only! (he says the trans has 50k miles but theres no proof for that)
KYB AGX in front, Coil Overs in the rear
New front axles
Big 2g dual caliper brakes
4 bolt lsd rear end w/ Redline Shock Proof(also in t-case)
Non-ABS
Manual steering rack(he says ever since he installed this the car pulls slightly to right but it just needs a alignment?)
15" motegi rims(tires are pretty much bald needs new ones)
Full interior in very good condition
black leather in back/ mint
cloth up front/good
black vinyl headliner/mint
sunroof/ no leaks
air cond. eliminated/ heat works
Sony head unit w/ removable face
stock tweeters in the dash sound great
Rockford Fosgate in the doors and rear
NO GAUGES ONLY BOOST! NO WIDEBAND!
also says it has no boost or any kind of leaks...and compression is fine all the way across.197,457 miles on the odometer
The hood on the car sucks it has a mitsubishi logo etched threw it in the front middle area and he says in rain or snow it harldy gets in the engine bay and if it does it dries up right away...it seems it would fall around the headers area so its gonna need a new hood or sum sheet metal to be placed under that logo to stop water from getting in or anything else...Or do u guys think its not a big deal?
Lots of mods for the money- could use a little underhood cleanup, though. I never understand why someone would dump so much into their car and not upgrade something as simple as the intake pipe.
Turbo's a knockoff....I think the MBC is installed backwards, too.
If you can get it for $2000 them go for it but it is an auto. Sounds like a sound investment but do not overpay.
There's nothing wrong with an automatic car if there done right they shift faster and more precise then a 5 speed, plus your turbo stays spooled all the time.
Im just worried about buying it because the holes in the hood who knows how much water and crap got inside but the seller says it really dont and if it did it would dry up real fast from the heat in the engine bay...but as u can see the manifolds are starting to rust up and the intercooler pipe but otherwise the rest has no rust i can always polish the manifold and pipes i guess...
If you do buy this car, please put a upper timming belt cover on! Also for the hole in the hood, you could put a piece of plexiglass underneath and use some type of seal around it.
