should i buy this talon?
brianhan
Jan 12, 2005
san jose, California
i found this talon on a local classified and it said
I HAVE A 1991 EAGLE TALON TURBO ALL WHEEL DRIVE BUT NEED TO LET IT GO BECAUSE I AM EXPECTING A BABE BOY SOON AND I NEED THE MONEY THIS CAR IS IN GREAT CONDITION BUT OTHER WISE IT JUST HAS THE BASIC FADING PAINT SPOTS HERE AND THERE , I REALLY DONT WANT TO LET IT GO BECAUSE OF ALL THE NEW PARTS THAT HAVE BEEN INSTALLED ON THE MOTOR DETAILS....price nego.
NEW PARTS ...
WATER PUMP .
TIMING BELT .
BALANCE SHAFT BELT.
REBUILT HEAD.
REBUILT TRANSMISSION.
FUEL FILTER.
VACUM LINES.
CLUTCH KIT (ACT 2600 PRESURE PLATE, AND STREET DISC CLUTCH).
TIRES.
RIMS (2000 MITSUBISHI GT V6).
ALTERNATOR.
APEX B.O.V.
UPPER INNER COOLER PIPING.
EXAUST PIPING (2 1/2).
MAGNAFLOW MUFFLER.
JVC CD PLAYER(NEW)
ROCKFORDFOSGATE SPEAKERS(NEW)
CAR ALREADY PASSED SMOG IVE GOT THE PAPERS FOR THAT, CAR HAS 131,000 ORG MILES.
TURBO SPOOLS GREAT BUT SMOKES A LITTLE BIT MIGHT NEED A NEW ONE SOON IF ANY OTHER QUESTIONS PLEASE FEEL FREE TO CALL ME AT ANY TIME AT
my only concern is the turbo smoking, what does this mean? would it affect the performance of the car and how much would it be to fix? how much do you think the car is worth with this? thanks in advanced
first of all smoking is always a performance decreaser, but if its just a crack in the exaust manifold, which it most likely has, thats no big deal, cuz an evoIII exaust manifold new would run you 300 max, and that would be a nice power increase. if it is the turbo, then you might need a new turbine housing, what type of smoke is it, black, white, does it smell like exaust? a new turbine housing will run 100 max, and a new 14b can probably be found for 250 used. a evo III 16g turbo, which is a nice performance increase (LOL,... nice, its GREAT from what ive heard...ie flows a LOT more and runs higher psi...) and a new evoIII would cost about 600 for all the gaskets and the turbo, if you install yourself. but if you do get an evoIII you will want some bigger injectors and a better fuel pump, unless your going to run the stock psi... then just the turbo will be fine.. either way id try and get him to go as low as possible, and depending on the exterior/interior, dont go above 3k for it... aim for sub 2k
