Shifter cable bracket
OK thanks I'll order that now. The reason I ask about the cable bracket is my shifter is not sitting in the normal neutral position. Neutral is forward like its in 1st 3rd or 5th
You only need to order the select lever shoe if it's missing or worn down out of spec. If missing you definitely will have a problem. It is used when shifter is moved right/left to select the gear pair (1-2, 3-4, or 5-R). But if missing all kinds of bad things will happen.
