SHAVED REAR WIPER WITH spoiler
looks good but now you don't have a rear wiper... I don't have one on my RS and it sucks sometimes, especially when there's snow
i'm in the process of getting rid of the rear wiper as well. i don't have to worry about snow though cause i only drive my mitsu in the non winter seasons. looks very good though, hopefully mine turns out that good!
Also don't have to worry about snow if you're driving fast enough. :D
Actually I just finished installing CF hatch and I'm having a heck of a time deciding if I want the wiper back on there.
looks good....planning on doing this as well :)
Good job! it looks very well done/clean. i wish i would have done that good of a job plugging my spoiler holes when i put on my high rise spoiler LOL
ive not had a problem in the rain seeing with out the wiper but idk if it will see snow again.. ill get a beater with heater for that LOL
THE STEPS I TOOK TO DO THIS:
I made a patch out of thin old furnace duct for the back side of the wing jb welding it to the back side of the wing giving the bondoglass something to adhere too then i scuffed it up used a few applications of bondoglass as the filler material cause its water proof flexable and sandable then to finish it off i used the finishing putty sanded it and primed it checked how level it was sanded it back down to get it looking right i also reccomend a dark colored sandable primer to see imperfections and smooth them out b4 paint and clear and thanx for the support
Looks very professional. I was just thinking a short while ago that I'd be stuck with the little bolt hanging out of my rear spoiler since I hate the rear windshield wiper. Now there is hope. Thanks.
Since you remove the antenna do you have the in body antenna or no radio period ? I'm somewhat interested in this as well
you may have broken one of the support brackets that mounts the wing
i have my radio i just bought a flat sticky window antenna and put it in the rear window or ill use the old squirter hole for a small 1 inch antenna
Does any one know why the rear middle spoiler could dip lower than the small side spoiler? mine is really uneven.
Thanks
under the spoiler there are black and white plastic clips that holt it to the screw heads on the hatch. are they upside down. are some missing. is the sheet metal on the hatch dented in.
iugrad92turbo's talon has a different spoiler than mine!!!! my car is an eclipse not a talon 2 different rear designs
Thanks
you may have broken one of the support brackets that mounts on the wing happened to me my spoler dips down identical havent gottten around to creating a fix
Thanks
you may have broken one of the support brackets that mounts on the wing same thing happened to me my spoiler dips down even on the identical side havent gottten around to creating a fix for mine yet ill let u know if i do
I had to rework these brackets for me to put it back on. It was always crooked.Maybe its the hatch that runs down on one side. I need a new hatch anyway. Its rusted and water is running in through the weatherstrip.
The hatch in my 1994 Talon is leaking :(. I need to fix it and fast. If you have any tips on how to fix that leak then please tell me as my hatch has zero rust and has an almost new window in it.
how much do these cost and are they easy to install? are they also as good as a stock antenna? my rear hatch as also shaved of everything.
it works ok and u have to reroute your antenna wire up to where u are relocating your antenna too and just plug it in
check your trunk alignment and bump stops at the bottom u can adjust them a little or u need new seals if that doesnt work
