Setting up AFC
gamingguru
306
Jun 8, 2004
Merriam, Kansas
I some help setting up my SAFC2. My mods are in my profile. I have a wideband, but the exhaust is leaking around the turbine housing because it is only held in by two bolts(I was expecting my wastegate last week) so it isn't much use to me right now. I set the low and high Maps where they came from the factory. I set it at 25% extra airflow for both the low and the high maps on the AFC. The car will turn on and idles somewhat fine, as good as can be expected with one coil of the ISC motor burnt out. The problem is that whenever I try and get on it even a little, like to pull out into trafic from a 2 way stop, the car just stalls. I am not really sure what is causing this, I think that it might be fuel cut but am not really sure. I have a aeromotive AFPR up in my room but haven't got the hose yet to put it in. MY other thought was that since the fuel pressure is probable really high the car is flooding whenever I get on the gas a little. I have a data logger that I hooked up and my timing is around 22-30*. I am not really sure if this a a good amount of advance or not.
Let me know what you guy think about this problem and how to fix it.
Ok, how does this sound:
-18% -19% -20% -25% -25% -25% -32%
For some reason it just made sense to me that since I would be flowing more air I should let the computer in on that an set it for positive number instead of negative ones.
Hey, and thanks for not offering up any usefull information with that post....
