serial number stamps missing from turbo
nathansgsx
41
12
Jun 7, 2017
Meridian, Idaho
Took the turbo out because wheel needs to be replaced and discovered that my compressor housing has no numbers to identify what 16g it is, atleast I was told it was a 16g. It has the 49178-01 but no numbers inbeteeen that and 0 and none next to S.
Maybe it was new old stock or something as to why it might not be marked? I think the casting looks like an MHI or a really good knock off. The ones I have seen usually have the SN stamped in and some numbers stamped in where 01 XX 0 would be. Do the fins on the compressor side have 2 close and then spaced and 2 close? the 16g ones I have seen look like that.
Thank you for all the help this community is seriously so great. To answer your question the fins are 2 close and then spaced and 2 close. I tried the dirt method and nothing came up so I just measured the wheel and the sizes matched up 1:1 with the measurments of an E316g so thats the wheel I ordered. I'll investigate more to see if I can discover anything else but as far as I can tell the turbo seems genuine.
