sensor above intake manifold
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
ok im wondering what is the sensor that is bolted to the firewall that is right behind the intake manifold/throttle body? It has 2 wire and it has a vacuum line coming out of it. Also i never noticed this on my car and i def didnt do this but the two vacuum line nipples on top of the throttle body is capped off. there is a small hose running from one nipple to the other. and the sensor im asking about has a vacuum line that is just hanging there and im pretty sure it should be connected to one of the vacuum lines that are capped off. I have no idea what this sensor is so.. ya sorry i dont have a camera right now but ill try to get a pic up if nobody knows what im talking about. thanks
hold on ill post a pic up in a sec i think my buddy has a camera i can use
ok heres a pic the red is the sensor and the yellow is where the nipples are capped off. p.s. - the reason im asking is b/c my car wont boost past 10psi with a brand new turbo.. did boost leak test and no leaks so now im checking for vacuum leaks, bad MBC, bad BOV, etc..
ok heres a pic the red is the sensor and the yellow is where the nipples are capped off. P.s. - the reason im asking is b/c my car wont boost past 10psi with a brand new turbo.. Did boost leak test and no leaks so now im checking for vacuum leaks, bad mbc, bad bov, etc..
see if this helps
  • Wanted 6 bolt NT water pipe
    • chrisman287
