all black 4G63
5+ Year Contributor
278
51
Aug 5, 2019
Chicago, Illinois
Has anyone disassembled the drivers seat track slider rails on a 1G? Looks to be a roller stopper that hits a pivot machined in the track.
Does anyone know if it is possible to disassemble the seat track slider assembly on 1G? The sliders seem to stop on a roll stop pivot machined into the track. Is it possible to remove the upper track from the bottom??
thanks
So if anyone is wondering the Sparco QRT seat with 600 series side mounts mount right up to the factory seat slider tracks, the tracks just need to be modified by removing the factory seat mounts that are spot welded and riveted in. Then the 600 series steel side mounts will weld right in..
