Sealing up the fuel pump assy
Quasimondo
2,659
66
Jan 17, 2004
Washington,
My fuel pump assembly is leaking at the top where it bolts into the tank. What can I use to seal it up?
for a temporary solution you could put some silicon sealant on there. Heres the thing I just dont know how gas will react with the silicon sealant. Might be fine might not, i am no chemical engeneer you know? now for a permanant soulution can you get a pic of exactly where its leaking? It might be easier to come up with a better soulution then.
The gas has evaporated, but it was leaking out from where the assembly bolts down into the tank.
