Sealing Aluminum Polish
6-bolt
50
May 22, 2006
Thornton, Colorado
Just got done polishing my JM Fab intake manifold. Since aluminum dulls pretty easy, can I seal the shine in with a clear coat of some sort? Don't want buff it all the time. Plus almost done with the valve cover. I have attached a pic of the manifold below.
Darren
www.6bolt.com
After doing some research I looked into sealing the Aluminum with a high temp clear coat. I pick up a bottle of Dupli-Color High Temp Clear (DE1636), and tried it out on the back of my intake manifold. For starters, here is what it looked like after buffering.
I took off the wax, and got ready for the clear.
After the clear coat.
After three hours of curing.
I will let it dry for the recommended 24 hours. It has some orange peel. I will sand and buff soon, but I will remove the wax after buffering. I am sure the heat from the intake and valve cover will melt the wax. I will post pics of the experiment when I am done. If this doesn't work, looks like I am going to try the Zoop Seal.
Darren
www.6bolt.com
This is supposedly the sh!t!!! http://www.zoops.com/zoopseal.asp
http://www.zoops.com/zoopseal_faq.asp
Expensive, but probably well worth it in the end.
^^^ This stuff is awesome. I've been selling it for years to the muscle car crowd and they love it. They put it on everything from intake manifolds, to valve covers, to wheels. it is expensive, but they all tell me, "to get what you pay for with this stuff".
Once I get enough polished equipment under the hood, I plan to buy one of these kits and seal everything up.
What did you use to polish the IM? I just got my Greddy 24R and I want to polish the endtanks.
Just got the kit from Harbor Freight for $20.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94962
Then I used my pneumatic drill with the attachments. Please note that I did a lot of sanding. From 400 grit to 2000 grit. An easy way to clean the metal before buffering, is to wet sand with 2000grit. It will clean the metal fast. Just used my sink and 2000 grit sand paper.
More details at:
http://www.6bolt.com/current_status/10_28_2007/default.htm
Darren
After doing some research I looked into sealing the Aluminum with a high temp clear coat. I pick up a bottle of Dupli-Color High Temp Clear (DE1636), and tried it out on the back of my intake manifold. For starters, here is what it looked like after buffering. I will let it dry for the recommended 24 hours. It has some orange peel. I will sand and buff soon, but I will remove the wax after buffering. I am sure the heat from the intake and valve cover will melt the wax. I will post pics of the experiment when I am done. If this doesn't work, looks like I am going to try the Zoop Seal.
My experience with the above has been when the paint gets hot, it turns a amber brown color instead of clear. I would go with something else.
Well I tried the high temp clear coat and it didn't work. The clear coat was to cloudy, even after sanding an buffering. Tried so much, I broke through the coat. I putting in an order for Zoop Seal tonight. Thanks for the help. See pics below.
