snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
Over the summer I had done a full brake job, including rebuilding all 4 calipers and installing new PowerSlot slotted rotors, Axxis MetalMaster pads, and ss lines all around. With the rear of the car jacked up, when I spin a wheel, I get a scraping sound. I tried adjusting the e-brake from behind the rotor and also at the line under the center console. Neither of these have helped. I also thought maybe the rotors needed set or the pads needed worn down a bit, but after properly seating the rotors and driving a bit more, it's still making noise. I have a few videos of it that I included.
I had started a similar thread right after completing the brake job - http://www.dsmtuners.com/forums/handling-tech/264136-new-brake-system-problems.html
Passenger's side:
*won't upload for some reason*
Driver's side:
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/9sllXN1TZNs&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/9sllXN1TZNs&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Passenger's side:
Driver's side:
