scm6176 with .82a/r housing
91-gsx
932
11
Mar 31, 2005
San Jose, California
I was wondering if anybody knew much about his turbo or could show me info about it or personal experiences, dyno numbers, anything? I decided to go full t3 and would like to know what rpm this turbo would spool at with a stock block and head?
thanks for the help
Wow, nothing on this turbo huh? Well I found out that it is called a sc6176 without the m because I will not be using the bolt on mitsu housing. The 6152 has a 52 turbine and then there is a 69 turbine and the biggest is the 76 turbine. The 6152 with the 3" E cover is rated at 630hp, the 6169 is rated at 650hp with the 3" e cover, and the 6176 is rated at 680hp with the E cover. Now remember the bigger S or SP housing is good for another 50hp on top of what each is rated at. That makes a sc6176 capable of 730hp as opposed to the 680hp that the sc6152 can push out tops. Here is a link were I found the info, only hard info I could really find so far.
http://www.turbogoods.com/index.asp?PageAction=VIEWPROD&ProdID=20
I am posting this for future reference for others as well as updating you on the info I have gathered. Anything anybody could add will be very appreciated.
later
