Sbr 3500 Clutch Disk + Act 2600 Pp Info Asap
Drifter27_04
335
Feb 13, 2005
Winston Salem, North Carolina
Are there anyone running this setup and how is it holding up. I would like to get some feedback ASAP b/c I will be placing a order for a sbr 3500 clucth disk soon to replace with my ACT disk.
Thanks to all
OK, I have decided to go with either a ACT faceplate disk or a Sprung 6 puck disk with my2600 PP, What are some of you DSM members think of one of the two disk would benefit me with my mode's
I would go with the face plate disc, because mine is a DD, and the 6 puck is a little more of a rough track disc. So if you go to the track a lot then go with the 6 puck, if you go once in a while and do a lot of DD then the face plate disc. Hope that helps.
I have been using the sbr kevlar disk on the 2600 and fidanza flywheel and have been doing great. I have worn mine out, it held good for 8-10000 miles
Thanks for all the help guys.
I went ahead and purchase a replacement clutch disk from ACT and installed it over the weekend. I had run into a problem with disengagment problems but hopefully after welding the clutch assembly it will work.
