Say Something About The Person Above You
Status
Not open for further replies.
Is in a better mood then yesterday. Sleep must have calmed him down a bit. Glad to see you back with us. And again I hope everything works out ok.
I have never been to Denver but I want to go someday. Especially if the weather is good.
Should check if he is able to push in the slave cylinder rod with his finger if not should try adjusting his clutch pedal. You probably have the bleeder valve in the master cylinder blocked from the rod being out too far. But this is all if you've recently tried adjusting your clutch.
Also did you put the clip back on the clutch fork and TOB when you were putting the trans back on?
knows now that I have not adjusted the clutch. Before this issue, the engage point was a little off. I'd grind sometimes going into gear from a dead stop, but after that, it never really happened. I've got the car parked @ A bank down the road, and once the traffic dies down I'll get the car to a garage so I can look @ it
Has found the secret to liquidizing solids. Must be that Jack-O-Lane pie juicer LOL
Knows It must just be a midwest thing..Apple pie is apple cider or juice with cinnomin and everclear..You cook it on the stove in a pot, and when you drink it, you can't taste the booze..It just basically tastes like apple pie..
Should just throw cider, sum sugar a bunch of cinnosticks, and everclear together cook it on the stove, not boiling for a ohh, half hour..Bottle it back up in the gallon cider bottle, plus probly a 2 liter..The best way to drink it is to let it sit in the container for about a week to soak up the cinnosticks, then enjoy..Ohh and you can also add sum cherry juice if you want to..
Status
