Say something about the person above you. Pt II
Knows that's a good idea. My ultimate DD is a Speed6.
Should know I have a POS '90 Integra for a winter beater. It's just something I don't have to care about and get two miles to work everyday in the cold. I plan on getting my AWD Talon running and driving that everywhere else.
Should know mine isn't. I think the cat is horribly plugged cause my last tank was 22 mpg and that's the non-v-tech 1.8L.
May get bad mpg because of a lot of short trips; that'll kill mpg even on the most efficient motor. Especially in the winter time.
Low tire pressure can be a culprit. A clogged air filter can cause irregular richness and lead to poor gas mileage. Loss of compression somewhere in the motor can cause it. Maybe it's just age. Is it very elderly with a lot of miles?
Should know I did plugs, wires, air filter and oil change when I got it. It has 293k kms though. I'm pretty sure me running seafoam through it is what plugged the cat since it didn't smoke at all when I did the seafoam and since that, the cat gets hot even after a short drive.
Should I put it into the intake manifold and I changed the oil and plugs & wires right after.
Should know that's why I think the cat is plugged; it didn't smoke at all when burning seafoam.
Knows wastegate dumps sound good.
