saturn alternator main power wire routing?
Funfettie
419
Sep 19, 2011
Menomonie, Wisconsin
I just completed the saturn swap in my 2g, and i havnt been able to find anything on where to rout the main power wire. I routed it to my power distribution block in the engine bay (battery relocated to the truck) but I have lost all power to my interior electronics (windows, locks, blower motor, lights) so im wondering if i should just extend the main power wire on the original harness so it goes back to the fuse box? If that is the best option, do i need to replace the fuse with a higher amp fuse to work with 96 amps?
Thanks
I put mine in the trunk too n I see u have no power to anything in side u check the wire on the fuse panel. I routed my alt wire to starter then from starter to distribution block. Then on distribution block I ran 2 4 gauge wire to the fuse block I connect one to the alt side n the other right on the side of it Its like n L shape u got 1 spot then 2 spots one of the 2 spots is for a spare 60 amp fuse on the inner L side first one is the wire that powers the fuse panel to the inside then the next is the alt fuse that one n the one to the right of it like I said form n l shape is those guys to that run to distribution block n that's all the wires u need running to block if u have any more questions just pm me or reply on thread n ill keep o o check back on it.
At 3 or 4 ill go out n take pics just in case u still don't understand the wiring part
Check out my images on my profile to get a better understanding hope this helps u out..
Be sure your getting power ran to the fuse box and with proper size fuses. I ran a 160amp saturn alternator and kept blowing the main fuse.
