SAFCII Stuck in DEC-AIR menu stuck
VPrime
802
3
Feb 5, 2006
Lonon, ON, Canada
hey guys got an issue with my safc 2 that I am not sure how to fix...
For some reason it is stuck in the DEC-AIR menu. I can only scroll through the 3 options, but that's it. How can I get out of this menu!?
Also, my throttle does not work. It is wired up correctly, but the afc was showing 0.083 in the sensors screen... WTF
Thanks.
There is no news of this anywhere,not on their website or anywhere else so please expalin more so the rest of us that have this can have some info on the recall as well?I have looked for some info and cant find anything.
Guess no one has a fix?
Does any one know how the AFC stores the data? I know that if you cut power to it your settings are not lost.
So that means it must have a writable chip.. and probably a battery to keep it stored?
Any one know if this is true? I am going to try opening it up and hope to find some thing in there to help reset it.
I just hope that the AFC software is not store of a flashable chip ;)
Push the center knob to the left. That will take you back one menu.
Was this a new install? Or is this a new problem that showed up?
Make sure you tied into the correct pin for the TPS sensor.
I tried every thing with that knob. It is stuck in that menu.
It is a new install, but this problem appeared 2 weeks later.
It is wired according to the picture on the VFAQ.
wow thats some bullshit. I've herd nothing good about SAFC, but then again i haven't herd much. stuck in a menu huh? what a piece of shit. I've herd SAFC is the cheapest way to go too, but then again i could be wrong.
I'm sticking with the MAPECU2. they have a forum and the creators of the MAPecu check it everyday. you should check it out... It's really good shit.
if anyone feels like telling me whats up then feel free.
oh yeah the guys at MAPECU will make a map for you too. basically any car...
  • Wanted 6 bolt NT water pipe
    • chrisman287
