safc tuning suggestions..please.
tim18t
Jan 17, 2006
hoffman estates, Illinois
here's my mod's
built bottom end
272's
fp3065
pte 1000cc injectors
keydiver chipped eprom for the 1000cc's
gn maft set for stock injector's
walbro 255
external regulator set to 37 psi
according to my wideband the car is crazy rich (peg's the aem on 10:1) at 15 psi thru the rev range.
im looking to bump the boost to like 18-20 on pump gas but i obviously need to take some fuel out.
do i need to set the afc any differnt for the maft? also what about injector size? do i set up the afc as if they were stock since the ecu compensates?
........................If you can afford that then why in the hell can you not afford DSMlink?
look at it this way, save your money.
Then get a bigger turbo or something that you will not being running the car for.
Then while your doing that, take out your SAFC, logger, and other tuning setup items, and sell them on here.- you could make like $400+ if you sell teh SAFC and the complete logging setup.
then, go buy a dsmlink, hook it up. Then retune with your new DSMlink:thumb:
Besides The SAFC is most likely not sufficient to anything that high ( 1000cc), however I have had no experiance with compensating eprom chips. so that may help you there.
i think i have enough turbo for now.....but yeah i see your point. i probably should have just bought dsmlink, and will eventually. but my next big adventure is going to be a transmission.
