SAFC Karman Monitor question
sickandtwisted
Jul 25, 2002
Oley, Pennsylvania
I installed the SAFC 1 in my 91 talon. I bring up the moniter settings and the karman stays at 3 htz,and does not change at any rpm. Is this normal? I have it wired into pin number 10 odfconnector c-61 the mass air flow return signal wire.Everything else with the SAFC works the way it should. Let me know if this is normal or if I wired it wrong.Thanks
Yup, it's wired wrong. You should have cut the airflow signal wire in half, and connected each side to a different wire on the SAFC.
