SAFC install problem
firehawk
169
Oct 17, 2003
Vandergrift, Pennsylvania
Alright so I am trying to install my SAFC I...everything with the 24 pin connector is fine. The problem I am having is with the little 10 pin connector.
The vfaq on vfaq.com says to connect the red wire from the safc to the red with black stripe power wire which is the 2nd wire from the right on the bottom.
Well my red with a black stripe wire is 3rd from the right on the top, and in the 2nd from the right on the bottom is a solid red wire.
Now to the ground wire....it says to connect the brown wire from the safc to the black with orange stripe which is on the bottom row, furthest pin right
Well I dont have a black with orange stripe at all. I have a black with yellow stripe, but even that is 3rd from the right on the bottom. What I have in the spot where it says im supposed to have a black wire with orange stripe is a solid black line.
(obviously I have a problem connecting the black wire of the safc as the wire is wrong as I just stated)
So...what do I do? Any help would be greatly appreciated as I would like to install this tomorrow morning.
Thanks,
Brandon
reference to vfaq: http://www.vfaq.com/mods/gvr4_afc_instructions.html
